Old 21-09-2005, 12:45
Gert's Avatar
Gert Gert is offline
Default Iemand zo'n ding op zijn of haar werk staan ?
Bij ons onder de brug hebben we geen stroom ..
How To Hack A Soda Machine
Most modern soda machines have little computers in them. The tiny RED LCD usually displays the data. The computer can be controlled by using certain buttons on the soda machine in different combinations. This can be used to check the temperature, see the amount of money (load and dump), and dump certain sodas. Will usually only work on newer machines that look like the one on the right. They need to have an LCD and also need to have some type of message on it “ICE COLD SODAS” This tells you it is running something.
1) Accessing the Menu: Press the buttons [4][2][3][1] one after another. It will be left to right in some machines and up and down in some so try both methods. Once you press these keys you will be in the “debug menu.” It should display ERROR or something similar.
2) Once you are in, button [1] becomes the back/exit type of command. Button [2] becomes scroll up. Button [3] becomes scroll down. And Button [4] becomes select/enter. You can now scroll through the features.
3) As you scroll through the menus you will see items such as SALE, CASH, VER, ERROR, and RTN.
4) What each item means: Cash- displays the amount of money in the machine. You will also be able to find more info on what was purchased how much for each item and are arranged by slot #s. SALE- shows how many drinks have been sold and how many from each slot. (slots are in same order as buttons so if button 1 is coke then slot 1 is coke as well.) VER- the machine firmware version. (pointless) ERROR- COLJ (Column Jam), VEnd (Vend Mechanism), Door (Door Switch), Sels (Selection Switch), CHAR (Changer Errors), Acce (Acceptor Errors), Sts (Space 2 Sales), and bVal (Vill Validators). (can’t do anything w/ this either, except clear the errors!) RTN- Returns back to normal menus, you can also do this by pressing on the coin return button or the back button. Also by holding a coin at the tip of the coin slot it will display the current temperature of the inside of the soda machine.
Update: This page has been viewed by over 10k visitors a day! Please help me continue hosting this site by donating a few bucks via PayPal. Any amount is appreciated. Thanks for your support.
5) There above are the options that are usually enabled, but most other options are usually disabled if the owner (or maintenance dude) is smart. But if they happen to be enabled here they are: CPO- Coin payment mode, which will dump coins out of the machine. You will be able to specify the type (dime, nickel, ect.) and the amount. tvFL- tube fill mode, which lets you fill the machine w/ coins. (retarded huh) PASS- allows you to change the default password from 4231 to something else. PrlC- change the price of a drink! (1 cent!) StOS change what each button links to (so if some1 presses coke you can make it go 2 sprite.) COn- are machine configuration settings too much to tell just experiment. TIME- Set TIME. LANG- change language.
Old 21-09-2005, 12:53
Alexdundee's Avatar
Alexdundee Alexdundee is offline
ja, hoe zien ze er presies uit...
Harrogate and District VW Club
VW Festival, Leeds. UK.
'64 Splitty , '66 Beetle and '74 Bay
Old 21-09-2005, 12:55
Gert's Avatar
Als je goed leest dan gaat het om exemplaren met een rood display
Old 21-09-2005, 13:00
Christiaan's Avatar
Approaching the redline...
heheheh... zoiets staat wel bij ons op de zaak ja... echter ben ik daar bijna nooit (zit vooral bij klanten).
maar het "default" password werkt bij ons niet, dat is al eens uitgeprobeerd :p
Cabby
Old 21-09-2005, 15:16
Alexdundee's Avatar
Ik werk op een grote Universiteit hier in Engeland en zal hier en daar eens kijken wat er staat en proberen natuurlijk, Cool.
Old 21-09-2005, 15:57
SplitBien's Avatar
SplitBien SplitBien is offline
hmm wij hebben ook zo'n apparaat beneden en ik kom er elke dag om blikjes te halen......
Gert's Avatar
Uitprinten dus en uitproberen
Old 21-09-2005, 15:58
SplitBien's Avatar
1 ding daar las ik ff overheen geloof ik....
hoe haal je er gratis blikjes uit?? Dat bespaart me ongeveer 2 euro per dag!!!
Old 21-09-2005, 16:08
Gert's Avatar
Ow ow .. dewegwerpjeugd
Als je blikjes in de supermarkt koop scheelt dan iets minder maar wel geheel legaal
Old 21-09-2005, 16:17
Misschien drinkt ze voor die 2 euro wel 4 blikjes per dag, en dan scheelt het niet zoveel
2006 BMW 320d Touring
2001 Golf Mk4 Variant 1.6 16v
Old 21-09-2005, 16:20
Gert's Avatar
3 es bedoel je ?
maar je kan idd gelijk hebben ..
