Go Back   Volksforum.com > International > Off Topic > Car Café Int
Old 28-05-2007, 00:00
Default the end of the engine as we know it?
sure there's the rotary (wankel) engine but the regular engines have been fourstroke's for over a hundred years. however popular science just did an article about a revultion in that department..
a 6!! stroke:
A typical engine wastes three quarters of its energy as heat. Crower's prototype, the single-cylinder diesel eight-horsepower Steam-o-Lene engine, uses that heat to make steam and recapture some of the lost energy. It runs like a conventional four-stroke combustion engine through each of the typical up-and-down movements of the piston (intake, compression, power or combustion, exhaust). But just as the engine finishes its fourth stroke, water squirts into the cylinder, hitting surfaces as hot as 1,500°F. The water immediately evaporates into steam, generating a 1,600-fold expansion in volume and driving the piston down to create an additional power stroke. The upward sixth stroke exhausts the steam to a condenser, where it is recycled into injection water.
Old 28-05-2007, 05:48
and to make it more fun:
the "air-engine"
http://www.ecogeek.org/content/view/659/
The world’s first commercial compressed air-powered vehicle is rolling towards the production line. The Air Car, developed by ex-Formula One engineer Guy Nègre, will be built by India’s largest automaker, Tata Motors.
The Air Car uses compressed air to push its engine’s pistons. It is anticipated that approximately 6000 Air Cars will be cruising the streets of India by 2008. If the manufacturers have no surprises up their exhaust pipes the car will be practical and reasonably priced. The CityCat model will clock out at 68 mph with a driving range of 125 miles.
Refueling is simple and will only take a few minutes. That is, if you live nearby a gas station with custom air compressor units. The cost of a fill up is approximately $2.00. If a driver doesn't have access to a compressor station, they will be able to plug into the electrical grid and use the car’s built-in compressor to refill the tank in about 4 hours.
(See link for more)
