Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk1
Old 03-03-2009, 20:14
silentdub silentdub is offline
Default Safe Easy Rust Removal
While cleaning up one of my web servers, I came across some pics from and old DIY I wrote some time ago.
I recreated it today.
Enjoy.
http://www.mk1dubz.com/forums/showthread.php?t=31
Old 03-03-2009, 23:30
lol, i like the kiddypool idea nice mental image..
Old 04-03-2009, 19:25
PerL's Avatar
PerL PerL is offline
So basically, you immerse the metal in water, hook up a battery charger's positive side to a conductor separate in the water, and the negative side to the part itself? Hmm, guess I gotta try this out
I read of another trick, to use vinegar. I've tried this myself, but it didn't work out as shown in this link. I guess my vinegar may have been dilluted.
http://www.cookhaus.co.uk/vinegar/index.htm
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 04-03-2009, 21:59
you need to use SUPER WASHING SODA, and set the charger to no more than 2 amps.
clearly it worked as seen in the pics.
Old 04-03-2009, 22:00
perfect for the rear axle beam
Old 04-03-2009, 23:39
Henk_Pigo's Avatar
Good method, much used by archeologists! Rust is basically an electric process and this method reverses it. The use of sode will increase the conductivity of water. Be sure to use soda since normal salt will also release chlorine gas (NaCl)
Be sure to vent the place since the charger will split the water in both oxygen and hydrogen!
Old 06-03-2009, 23:36
PerL's Avatar
I missed the part about the soda, and the pics didn't work for me the other day... (I can see them now)
Old 07-03-2009, 05:33
toth75's Avatar
toth75 toth75 is offline
i like leaning with vinniger better, no gasses and no current needed.
Golf5 1.9 TDI (daily)
Golf4 1.9 SDI (verkocht)
Polo 1.9 SDI (verkocht)
Golf1 Mk1 GTD Project(sleeping) '83 LO41
Golf1 Mk1 GTI Project(sleeping) '83 marsrood LA3A
Scirocco 1.6 (verkocht)
Polo 1.0 (verkocht)
Old 08-03-2009, 04:50
I fixed the picture permissions.
It works for me.
