Go Back   Volksforum.com > International > Off Topic > Car Café Int
Old 20-11-2004, 09:32
Chrispy's Avatar
Chrispy Chrispy is offline
Old Fart
Default new specs for the yankee
the engine's ready
Engine: 400cu 0.30oversized
Headers: Supercompetition 3.5”
Heads: 72cc Edelbrock D-port
Compression ratio: 10.75:1
Fuel system: Holley Carb. Double pumper 750
Fuel pump: mechanical High performance
Manifold: Edelbrock Torker
Camshaft: Crane fireball 294degrees
Timing change set: Double roller
Oil pump: Crane High performance
Pistons: Speed pro (rings included)
Connecting rods: C&A Magnaflux (single piston)
Cranck: stock, Fully balanced
Harmonic Balancer: Fluid damper
Ignition: MSD 7A
Rear end: yet to choose. Stock 3.75:1 or Race 4.10:1
Rims: rear 15x10”
Tyres: 245x15
Weight: about 1700Kg
The car will mostly be driven on the street. But an occasionly ¼ mile is done as well. So street/strip.
We’re not sure if we want a transbrake to be mounted in the transmission.
Can anyone tell me about the specific advantages of a transbrake?
So the next order will look like this:
TH400 streetfighter tranny,
TH400 slip yoke,
superstreetfighter Torque Converter.
allthough i don't have to pay shit, (it's not my car) i'm learning a lot just setting up the new engine.
My pall is from Surinam so you'll prob. know what kind of make it will be?
Yep, a '76 Pontiac trans am, painted black.
Eigen volkswagens eerst !!!
Old 20-11-2004, 18:43
why isn't Ramai onhere btw??
Old 21-11-2004, 01:14
TwinScrew20v TwinScrew20v is offline
Send a message via AIM to TwinScrew20v Send a message via Yahoo to TwinScrew20v
A trans brake reduces unsprung weight and rotating mass (only one inboard brake vs two as far out as possible). Which end is the trans brake on? Rear end? Or at the front? Im used to seeing them on the rear but Ive heard of them up front. Jsut keep in mind most of the vehicles stoppnig power is done at the front wheels.
Old 21-11-2004, 10:22
Chrispy's Avatar
Old Fart
if so, then this transbrake will be installed in the tranny. So i'm not sure what you mean by: "Which end is the trans brake on? Rear end? Or at the front?" we'll be bying at from TCI automotive parts. check http://www.tciauto.com/transmissions/ for details.
@Dutchman: he's loggedin, but not much. the kids fight over the pc, and mostly they win.
Old 22-11-2004, 15:26
Ive seen them at the gear box end of the trannys as well as at the rear differential around here (we have ALOW of 4x4 trucks that use these as well as 'the good ol' boys in muscle cars) Some slow the tranny down (keep the rear brake system and leave it in gear to slow it) or at the rear differential (which will slow down the rear axle) That site doesnt seem to explain their system...But looks to be at hte gear box end. May be something different than what Im thinking. I dont know? e-mail their tech dept and see what they can give you on benefits.
Old 22-11-2004, 19:18
Chrispy's Avatar
Old Fart
i've mailed them allready, but i was wandering if anyone of international members new more about it. they're the selling party, so they prob. say anything i want to hear.
