Old 12-11-2010, 15:04
bighead bighead is offline
Default Ground Zero GZIA 4100HP
4 x 65 Watt RMS at 4 ohm
4 x 100 Watt RMS at 2 ohm
2 x 210 Watt RMS at 4 ohm
GZIA-4100HP specs:
Damping factor:> 70 (1 KHZ at 4OHM)
Signal to noise ratio:>80 DB (Reference 1 W output)
Frequency response:10 HZ- 30KHZ
Input Sensitivity: 0.2 - 6v
Afm (WxHxL): 28 x 24 x 5 cm
Werkt prima. Er zit alleen een andere schroef in om de + kabel vast te zetten.
Prijs: 70 euro
